It's a 996 cabriolet M.Y. 99. Approx 75,000 km. The top won't open or close from inside the car using the switch. It will open and close using the key in the door lock. Fuses look O.K. Anyone had this glitch? Any suggestions?
Hello,
With the parking brake set check to see if the parking brake light is on. The system looks for the light as I understand it. If the light is not on try pushing the button on the parking brake in and out a few times. Also might set and release the parking brake while doing this, It worked for me. Next step might be a new swich in the parking brake. Good luck.
