Hi Folks
I've just been checking over the brakes of my 996 prior to taking it for it's annual inspection (MOT) due at the end of this month. All seems well except for some light corrosion on the front to rear brake pipe where it exits the undertray adjacent to the gearbox. Probably could clean it up to get it through the test but I want to replace it as soon as poss.
Has anyone on here ever replaced the front to rear brake pipe on their 996 or know the procedure.
Thanks in advance for any advice.
Cheers
I have never seen this problem so can't help with replacement. Is it just surface corrosion or do you think it's damaged the pipe? Maybe a quick clean with fine steel wool and some wax to stop any further damage.
Exactly what I've done for now. It cleaned up perfectly and I've sprayed it with cavity wax so I shouldn't have any problem getting the car through it's annual test.
Would still like to replace it in the longer term as I intend to hold onto the car long term and pass it onto my son.
Had a good look at tonight and replacement looks straightforward so I'll takle the job in the winter months when the car's off the road.
Thanks.
