Hi there
I've recently swapped to a coil over setup. Stupidly, I didn’t take any stock measurements on the standard setup before I fitted the new suspension.
I've researched a range of settings which go from minus 10mm for use on bumpy roads to a drop of -30mm for race / trackday setups. I believe the new Spyder is dropped 20mm. However I don’t have a base measurement to go from.
I don’t like the way Porsche quotes the ride heights from an underbody point as it doesn’t take into account any variance in wheel / tyres diameters, and is also a complete pig to measure.
Can anyone get a tape measure and measure the height front and rear from the wheel centre to wing/fender point vertically above the wheel. Let me know if you are on standard, row or m030 specs, etc?
Marcus
