Hello!
I removed my 996 C2 Manual '99 USA transmission today and one of the bolts (#4 in the WSM pictured below) was slightly stripped before I got in there and I had to use a bolt-out to get it off. I don't want to put it back in for obvious reasons, but it looks like previous owners have done the same.
Any ideas of the part number? I can't seem to find it in the PET.
Closest I could come up with is 900 378 076 09 which is also a M10 x 50 (I measured it) for the other side...
However, the head on #4 is an internal 12 point triple flange style and the head on 900 378 076 09 (#6) bolt is hexagon, guessing this is because of the tight clearance a standard hexagon bolt would not work?, and perhaps standard torx would not provide enough strain support at proper torque/bolt size?
Thanks in advance.
Should be able to use any M10-1.50 X 50 allen head bolt that is 12.8 grade. BTW, I could not find that bolt either, only the other 7 bolts are in the PET.
  • 4 months later...
Hi folks could anyone please tell me what size Torx tool i need for number 4 as i am at the same position and i cant get it out many thnx in advance
Hi there, check out this thread.
