Hi!,
this is the first diy i post here. This one is for a led conversion of the 3rd brake like in a 996.
Images and instructions are taken from spanish forum ForoPorsche.com. Post is here (Link to complete post at foroporsche.com)
First you have to remove the brake light:
Then i soldered the metal parts to avoid movings....
Then place the leds instead the bulbs:
now, you have to make the holes at the plastic part bigger: (just a bit, about 2 milimetres)
Close it and you have a nice led light, very bright and with led spots :D
Hope you like. Best regards
Edited by malopezn
You neglected to mention that the cruise control will not work if all of the rear brake light bulbs are converted to LEDs.
You will need to add a load resistor in that case. I used a small 12 volt relay with a 50w halogen bulb connected via the NC contacts, with the brakes light on the relay opens teh halogen bulb circuit.
I have no cruise control so i did not notice that issue.
What i was surprised for is that there were no warning about lights. In that case i would added the resistor.
Can you please add a diagram or picture? Thanks!
  • 4 years later...
You neglected to mention that the cruise control will not work if all of the rear brake light bulbs are converted to LEDs. You will need to add a load resistor in that case. I used a small 12 volt relay with a 50w halogen bulb connected via the NC contacts, with the brakes light on the relay opens teh halogen bulb circuit.
I have just installed the Depo 997.2 rear tail lights and the smoked LED 3rd brake lights for the rear and the electric spoiler...while everything seemed to be working, I lost my cruise control.
I am trying to get the details on how to install the resistor, how many and where to overcome the problem.
Perhaps you can assist?
