I'm looking at installing the Child Seat airbag deactivation bar in my 99 Boxster. Do I really have to take this to the dealer for programming or can I disconnect the battery put in the deactivation bar and reconnect the battery?
Yes, there is some minor programming that needs to be done with either a PST2 or PIWIS tester.
There are several members in the bay area that have PST2s and could help. Or if you are over my way I can change it for you.
If you want to go to San Jose I can do it. I will most likely be at the Parts Heaven swap meet in Hayward on June 6th and can do it there.
All, I had this done last month for my 2002 at a Porsche dealer and it is a free install from Porsche for 986's. Check with your dealer and have them speak to their Porsche regional rep if they are unsure.
Joe
Joe
:welcome:
That will vary from dealer to dealer. Some charge and some don't.
Great thanks for all the info. If the local Fremont Dealer won't do it I'll see if I can meet up with someone.
Joe
:welcome:
Actually not if you have the dealer call Porsche. Per Porsche USA, it's free. Both Hennessy and Ellis in Atlanta got same answer from Porsche. Just FYI.
Can a Durametric (Professional cable) and v. 6 of the software change the settings for the "Child Seat Airbag Deactivation Bar"?
If so, can anyone out there provide a step-by-step procedure for changing this setting? Thanks very much.
