Another item on my Boxster Project to solve..
2000 S steering wheel will not telescope. The release mechanism seems to be working properly on the underside of the column and I've pushed and pulled on the thing to the point I'm leery of damaging it. Is this a rare problem to have and is there a trick to unstick the thing? Wife is 5'2" and I'm quite a bit longer and we could use the adjustment.
Thanks for any advise.
Don
Don
I had same problem on my 01... just had to keep wrestling with it ! I guess mine had not moved in 10 years so it took some time to get it to break loose!
