Well Im just at a loss, the car runs great but the oil pressure dial is always at 5 or over after a short run. This use to always read 3 on tick over then upto five on an increase in revs, now its 5 and a bove even on tick over????
Please any top advice would be great as I just dont know.996 C2 2001
With the engine off, but the key turned on, the gauge should read zero. With the engine warmed up and idling, I normally see around 1.5-2.
I would suggest replacing the oil pressure sending unit.
Look for loose or corroded connections on the oil pressure sensor (covered here many times before).
most likely the worse case you will need to replace the sensor.
