Just got a Boxster recently and according to the maintenance manual, I need the spark plugs replaced.
I have been told to change them from the engine hood (soft-top in maintenance mode, removal of the hood,...) However, after having removed the engine hood, I can't imagine that any tool would reach the plugs! I am not mechanic and may be I am a bit clueless but I am wondering if it wouldn't be easier to change the plugs from under the car rather than from the engine hood.
Any ideas/suggestions?
Thanks for your help
What model year is your car.  And how many miles on it.
We remove the rear tires to replace the plugs since most of us do not have a lift.
It's a mid 1998 model, about 45000 Km (around 28000 Miles).
I have no problem going under the car as I have a friend who has got a lift.
However, I like the idea of removing the rear tires...
Thanks for your reply
Be sure to check the forum for the torque on the spark plugs. When I did mine (10 days ago) the DIY marked 22 lb/ft the Spark plug data (Bosch 2 tip) had a specification of 19 lb/ft. I did mine at 20-21. I understand this is a very delicate process of you over torque. Also the tools are available at snap on. I paid more for snap on but you can buy cheap at any place.
search for this topic:  good spark plugs, your opinion needed
I'm in the middle of this project now. I can't see any way you'd be able to change the plugs from the top side of the motor - they are most easily pulled out with both rear tires off the car.
You'll need to do the following:
Safely Jack Car, support on Jack Stands
Remove Rear Wheels
Remove Plastic Wheel Well Liner in forward location of each wheel
Remove Spark Plug Ignition Wire
Remove two hex hed screws holding each spark plug coil in place
Pull gently on rectangular spark plug coil to remove
You'll be left with spark plug still in car, about 6" inside the outer edge of the motore
Remove and replace each plug.
All plugs are relatively easily accessible, with the plugs closest to the front of the car being the hardest to get at.
Good time to change your oil too!
Here's some pics:
Drivers side of motor, showing middle spark plug galleyway with coil removed
Drivers side of motor, rear most plug, with coil removed
Spark plugs (the dark one was in the leaky middle cylinder
Cheers!
Gundo
Got the plugs changed last week-end!
That was really easy. At least easier than I thought...
Thanks for your advise.
Manu
