OK maybe I'm crazy but I notice that if I let my 98 sit in the garage for a week or so, then take it out for a spin, I have a thumping as if there is a flat spot on the tires. It lasts for maybe 2 to 3 miles, then seems to vanish. Funny thing is I notice the same on my 944.
Am I crazy (ok yes I'm crazy) or does this have to do with the soft compound tires on both these cars? I deal with "bling bling Subaru WRX zoom zoom ricers" all day long, (www.mspt.net , shameless plug) and have yet to hear anyone complain about this.
Is this just the nature of the beast? or what?
Yes. You may want check your tire pressures. Even if they are okay you may want to pump them up 5# if you are going to let the car sit for a while. Just do not forget to reset the pressures when you take the car out.
The 18" Pirelli PZeros that came with my car would flat spot overnight - every night. 100 degree lows, 40 degrees lows they would flat spot.
My Yokohama ES100 will start to flat spot overnight when it gets below 20 - that is kindof my signal that it is time to go to the winter tires.
In a way flat spotting is a good thing - it reminds you that your tires are not yet up to operating temperature. Flat spotting is dependant on tire compound, tire size, ambient temperature and time. I think of it as a tire 'feature' rather than a tire 'problem'
