This is a very hard hose with only two ends with special locking clips on each end that is part of the hose. One end goes into the the Intermediate piece part number 99611021553 right where the throttle body bolts to. The other end goes into some type of canister. I was cleaning the throttle body and one of the locking pieces broke. No dealer or Pelican Parts people can figure the part number, I really hate to take hose off to get number, Any help will be greatly appreciated
Edited by zman1858
Are you possibly referring to the "j-tube" that goes to the Air Oil Separator?
The red arrows are pointing to it here, as it passes under the transmission shifter cables:
Here is the other end where it goes into the side of the throttle body tube:
Note these photos are from a '98. Later 986's have a "Y" tube arrangement rather than a "J" tube that leads to the AOS.
If that is the hose you are referring to, here are the part numbers(referred to as part #5 in the PET), depending on your year and engine type (M 96.20,.21,.22,.23,.24.etc.):
5 996 107 145 06 Vent Line 1 M 96.20
M 65X 01420 >>
(5) 996 107 146 00 Vent Line 1 M 96.21/22
M 96.23/24
Regards, Maurice.
Edited by 1schoir
