2004 CS 95k miles. I have to replace my sepentine belt. It seems my tensioner pully is making a rattling noise. Has anyone had this issue? Do I need to relace something or might replacing the belt quiet it down?
If there is any wobble in the pulley (belt off) I would replace it (and any others that wobble).
It can be ugly and expensive when one of these break.
I replaced the belt yesterday, not too bad of a job (1 hour). It turns out that my water pump pulley is the one that's making the noise. The shaft slightly wobbles 1/8 to 1/4 of an inch. I could not find any instructions in any of the forums that address the removal and installation of a new water pump. Any help would be greatly appreciated as I am in south Florida where it is 90+ degrees here already so I don't want to let this go too long.
Craig
