Ok,
Left the sunroof open during a huge rain storm. The mechanic say it the control module. Since the car won't start and the windows don't work and the alarm stopped alarming. I guess he is right. Mechanic says that 800.00 should do it. So I was trying to see if any alumnus might know where you can order a pre-programmed EMC.
Any help would be appreciated.
garlins996
Oh, yea Didn't do so good on the first post. My car is a 2003 Porsche 996 S4
You can't order a pre-programmed alarm controller because it has to be coded to your DME and to each key for the car.
If the $800 includes programming time - the alarm control box is US MSRP $398.47 so the rest is labor.
You can get the alarm control box for less through Sunset Imports (Porsche Parts at Dealer Cost) but you are still looking at 1 hour programming time.
Great answer Thanks for your quick response. I will check in the Sunset Parts on line. That is the Porsche Dealer in Portland, Oregon right
Correct Sunset Imports sells Porsches in Portland.
