Hi, there
I have a 2006 boxster with auto trans. After three days outside parking, I found it hard to shift. I mean after pushing the button down, I can feel the shift stick is not moving freely, I have to pull hard to get to P, R, N or D. The resistance is constant, no jump or jerk feeling.
The problem usually disappear in morning when I drive it to work. It will come back after one day's lot parking.
Any one has any clue about this problem? Thanks a lot for any suggestion.
987 MY 06) Disconnect the shift cable on the Tiptronic, if it goes smoothly, check Tiptronic (rare). If there is still much resistance, disconnect the cable from the shift mechanism (stick) and move the stick forwards and backwards, if it goes smoothly now,suspect the cable, if there is still much resistance, the mechanism is the culprit. Finally move the cable forwards and backwards to accomplish the test. Replace or repair what's needed.
Thank you, RFM. This helps a lot.
