I have an intermittent problem with my rear hatch... Every so often when I try to open it, when I press the release switch nothing happens. That is the retraction actuator doesn't move and the latch release actuator doesn't move to the release position either.....
I took the lower scuff plate off to look at the retraction actuator and it seems that when the problem occurs the retraction actuator is stuck in the retracted (closed) position. In fact if I can get it to move it goes one complete cycle from closed back to the closed position. It won't stop in the open position....
I had a look through the manual but for some reason I don't have any info on the retraction system, only the fixed hook. I may be looking in the wrong section but without any info it's pretty hard to troubleshoot. There are no faults generated when this happens so I suspect it is a sensor or limit switch.
The only other thing I have noticed is that when the door is closed and I am unable to open it with the car locked I can open the rear glass which of course sets off the alarm. I'm not sure if this has always been the case but it may have some connection to this problem.....
Anyone have any similar issues with their Cayenne??
  • 11 months later...
Having the same problem with my wife's '06 Cayenne S. It's intermittent. Not sure what sets it off. Did you ever find a fix?
