I bought my 2003 986 S with a Vertex HID kit. The right headlight started to go out when I came to a stop and required me to turn the headlights off and on and fixed the problem. Now the right headlight won't turn on. It tries to fire but stays off. What's the simplest fix? I want to remove the kit and replace with OEM bulbs. How hard is that to to? I am looking for reliability instead of the HID look.
Please help.
Please help.
Shouldn't be hard to do. I'm assuming that you know how to remove the headlight units with the provided tool. By the way, they can be a tedious PITA to put back in! There will be a hold (maybe 1" dia.) cut into the rear removable cover on the headinght unit. you'll need to come up with a way to patch it. Hopefully, the person that installed these HIDs was not a butcher.
It should be a direct unplug operation and the installation of a new pair of halogen blubs. Pull out one of the headlight units and get a good look at it before worrying too much more.
These HIDs don't work out for everyone. Mine were a nightmare, although I liked the light! I put the Halogens back in.
also another solution is to replace the ballast or bulb .
to test it take the ballast from one side and plug it to the other side
if the bulb comes on then its a bad ballast if the bulb won't come on then
its a bad bulb. ballast or bulb they only cost about 10-20 bucks on ebay.
regardless whether its vertex or who makes it they use the same plug in.
if you buy the bulb buy a set for exact color match.
