What is the minimum thickness for the rotors for both the front and rear? I heard it was listed here but could not find it. Thanks.
Robert
This should get you started.
http://www.renntech....082entry18082
Paul
It does not say there about thickness, only about cracks.
I would say this - buy new set of rotors from suncoast as you will need them anyway, measure new rotors, then measure total thickness of you current ones and if measured difference is more than 5mm - it is time to put new ones on already even if you do not have cracks.
may be somebody could run it up until 10mm total diff but imho 5mm of wear is a good threshhold.
