Can anyone tell me if i can use part nr. 997-044-901-51 to upgrade the PCM 2.1 in a my05 cayenne?
  • 3 months later...
It depends on your model level (MODELLPFLEGE or MOPF) of PCM 2.1 Multimedia unit. PCM 2.1 Multimedia update CDs to model level A & B in 997- (911 BOXTER CAYMAN) kit are different from those one in 955- (CAYENNE) kit.
You have to check (press the "MAIN" and "TRIP" buttons simultaneously), whether your PCM 2.1 Multimedia SW version is at least 3.x (Unit:PCM 05024xxx) e.g. model level B. If not, you will need additional (CAYENNE) CDs to correctly update PCM 2.1 Multimedia unit to model level B or C.
000.043.205.47.003 PCM2.1 MODELLPFLEGE-A UPDATE 06.2005
000.043.205.50.001 PCM2.1 BOSE-UPDATE-CD MOPF-A (CAYENNE)
000.043.205.47.002 PCM2.1 UPDATE-CD MODELLPFLEGE-B (CAYENNE)
000.043.205.47.004 PCM2.1 MODELLPFLEGE-B REPAIR KIT CD-SINGLE MY06 (CAYENNE)
From the PCM 2.1 Multimedia model level B you can apply the latest common PCM 2.1 Multimedia update CD (Navigation MY08) for correct functioning of new DVD-Navigation disc in external DVD-Navigation unit.
000.044.901.40 PCM2.1 MULTIMEDIA UPDATE LEVEL-C MY08 (911 BOXTER CAYMAN CAYENNE)
DVD-Navigation disc is common for the both of 997- and 955- kits (identical release).
Notice: Above listed part numbers and releases may vary, so you should check corresponding TSB.
Edited by bleo
