Can anyone help or offer a fix
My battery died and was replaced today (996 C2 2003).
The PCM2 Nav and Radio continue to work but I am getting a system error message "No CD Changer Detected"
Is there something that I can do to fix this?
Many thanks in advance
Disconnect the battery for 5 minutes and try again.
Also, make sure you did not accidentally disconnect one of the fiber optic cables to the CD Changer when the battery was changed.
If that does not work you will likely need someone with a PST2 or PIWIS tester to match the MOST components again.
