I have the usual problem of after replacing the standard steering wheel on my 968 with a MOMO Competion wheel and removing the air bag (3ohm resistor substituted) that from time to time I have to have the air bag warning light reset with a Dealer`s Borsch Hammer which can be both time consuming and expensive for a 5minute job.
Other than the Durametric software/tool or Borsch Hammer has anyone identified or use an alternative tool to reset this warning light.
I believe that an interface possibly with Scantool software was developed but is no longer available and if this is the case any details of this unit would be appreciated.
AFAIK, the only tools that can reset an airbag light on a Porsche are the Durametric, the PST2, and the PIWIS.
Regards, Maurice.
there is a gadget out there that you can build, but i don't have the specifics handy on it - send me a note, and i'll bounce you the contact info - maybe they can help you build one
i use the durametric
  • 2 years later...
