I just noticed a ticking noise from what seems the RH of the engine at idle. Any ideas where to look. Only does it when warm. almost like a valve or plug...
Based upon your mileage, it could be your water pump starting to go out.
Wait until it's a very noticeable 'clicking', especially at idle.
Then take it in for dealer service under warranty.
Hope this helps.
Is water pump failure common on 997.1s? I had a seal go on mine that left a nasty puddles on my driveway. The dealer replaced the seal and the water pump under CPO warranty. It was scary to say the least.
