I don't know if the trans is interchangable but i can tell you that the pressure plates have different dimensions so you will have to sort that out as well. The distance from the pressure plate spring, where the throw bearing makes contact, to the flywheel face is different. Perhaps the clutch fork needs to be changed as well but i am guessing.
