The dipstick on my 2003 C4S has an upper and lower groove with a dot outside each of the grooves. Should the oil be filled to between the grooves or between the dots? My dealer always fills the oil to the level of the top dot which is slightly above the upper groove and I'm thinking this might be a little too much oil-is my analysis correct? Anybody know the volume difference between the upper dot and upper groove in case I need to drain some oil out?
I wish the Porsche owner's manual had more specific information on the simple stuff! :soapbox:
John
1.33 quarts is the difference between the two marks.
Loren, do you mean 1.33 qt is the difference between the upper and lower grooves or between the upper dot and the upper groove?
Thanks again,
John :D
