Hi
I just had my 2000 2.7 boxster in for a full service inc poly belt change and fuel filter as well as the free whell pulley on the alternator being replaced as it was seized. The car was otherwise in perfect condition when I took it in and the gearbox has always been as sweet as a nut. As soon as I got it back and drove it home, there was a crunching sound when selecting 3rd gear, almost as if I haven't pushed the clutch down far enough. Its a sort of metal on metal noise. Its much worse if you shift up at higher rpm, but in general the whole gearbox doesn't feel quite as 'tight' as it did before. Now the garage is saying its nothing to do with them and it is now down to the fact that the syncro is worn and would probably be cheaper to just replace the whole gear box. My real question is, could anything have happeend while it was being serviced to suddenly make my gearbox go all crunchy? All the other gears appear to be fine, and the crunch is much worse when downshifiting from 4th - 3rd.
Mike
Could be your shift cables. I don't know how the shop could have messed with those but anything is possible. If it is your cables it's a cheap and quick fix.
