I have plans to start servicing my convertible top that has not been working for a few months.
I was trying to find the link how to change the fluid with pictures, but I could not find it. Does anybody have the link?
I know that it might be the motor or cylinder too, but I would like to get the link that shows you how to get to the parts.
KL
Is the parking brake warning light working? If the warning light is not coming on with the handbrake engaged, it may be the handbrake switch activated by the handbrake lever is not functioning, which will also keep the top from operating. I changed out the switch on my '99 C2 and everything works great. If the warning light works and the lid operates but the top is not functioning, go for the hydrolic fluid check. Good Luck.
Parking brake warning light works, so it's something else. Thanks for the link Loren
KL
This DIY link was the easiest one I've ever done. My fluid tank was totally empty and that's why the top was not working properly. Now it works perfect every time. I feel like a fool for not using my top because of that for 6 months. From now on, I will also check that fluid every year to be on the safe side.
Thanks for the link Loren .
Kristian
Where would I look for leaks? I didn't see any on the garage floor. I guess it would be coming from the back part of the car?
KL
  On 5/6/2010 at 10:20 PM, Dharn55 said:
If the tank was totally empty you should check for leaks, must have leaked out somewhere.
