Novice mechanic question :)
I've seen my car lifted from the rear with a floor jack placed centerline but I never saw where the lift point was. Where is a safe (i.e. non-damaging) lift point when lifting from the rear with a floor jack?
Loren, I want to put my car on Jacks for the Winter. Where would you suggest placing the four lift stands under a 99 C4 Cab with Type II side skirts (the skirts are from the new GT3 look)? Thanks again for your help.
my996: It is not recommended that you put the car up on jacks during storage as rust may develope on the strut pistons. Rather, increase to tire pressure to maximum and store it on the tires.
