Can anyone send me a DIY on how to install diverter valves for my 996 turbo? Thank you and will appreciate your response.
The installation of the diverter valves and F hose is really simple. But to reach everything it is a bit difficult. That is why you got the possibility of lowering the engine to get a better access. see these links... Lowering the engine and this one is a pdf for valves removal: Diverter valves replacement. I did exactly like mention in those two links and it work like a charm... Good luck.
can you install the new dv's on the original "f" hose ?!?
I have installed agency power diverter valves and they fit OEM "F" hose...
Yes, you can use your original F hose for the new after market diverter valves.
If you lower the engine is it possible to exchange the turbo hoses and F hose without removing the rear bumper cover? I have a set of samco and in the DYI section it says this needs to be done but thinking it might not if engine is lowered?
What do you think?
What do you think?
for the F hose you don't need to remove the rear bumper but for the rest of hoses i don't know
maybe this helps
Edited by alex_55
