I'm going to replace the clutch in my 2003 996 C2 this weekend, and I need the torque specs for the pressure plate bolts and flywheel bolts. I've looked extensively and cannot find them.
J
Pressure plate (tighten in several stages and in diametrically opposite sequence.) = 17 ftlbs.
Dual Mass Flywheel = 19 ftlb. plus 120 degree final tightening angle.
The clutch job wasn't too dificult, considering I had access to a lift and a trans jack. The only hitch was the slave cylinder that wasn't working properly, so we made a trip to the local Porsche dealer to pick one up. (That part has appearantly been update 7 times since my car was built). I bought the clutch assy from Suncoast, they were very helpful. That's one project I would not want to do in the garage at home. Thanks again for the specs Loren.
J
