As I've posted recently, I've been lucky enough to purchase a 1988 911 Turbo. It's in outstanding condition. After fixing/adjusting a few odds and ends, the only thing that is less than brand new is the radio. Surprisingly, I don't have any issue with it's performance. I want to keep the car bone stock. But the light on the LCD display doesn't work. So I'm looking for some help here. Can it be replaced with an 'as-new' identical model? Can it be repaired (which is my preference)? And does anyone have the model number and manual for it? It's a Blaupunkt but is otherwise unlabeled.
V
Hello
check the factory code sticker for the Radio M Code, if Köln, Bremen oder Berlin the illumination bulb is a DIY item.
Otherwise most Bosch/Blaupunkt Services can help on that. Only the PCI System diidn´t get a update since 2001 so Program Code Identification and dural Tuner switching from Berlin and Bremen fails.
Grüsse
