Hi.
Today i was parking my car, and when i put the transmission in reverse, it was still in neutral. I tried to put it in drive, and still its in neutral. When the shifter was in reverse the gear indicator is in revers and second gear at the same time, when in drive the indicator was in drive and second gear as usual. This was after driving a while, and the car felt like normal when i was driving.
I stopped the car, and started it again, and then all was fine. Is this anything to worry about? It's the first time this has happend to me.
The car is A C4S 2003 mod. with tiptronic transmission, done 27 000 miles.
You need to have the transmission codes read out but it sounds like the transmission range selector switch has a fault.
