I mentioned in another topic, Door Lock Sensor, that I was having a problem with the gas gauge. The gauge would show the tank was full and not move as I used gas. I actually ran out of gas going to the gas station when I realized there was a problem with the gauge.
I'm 90% sure that the problem was a hose that had moved in the tank and interfered with the float. The first thing I found when I removed the tank gauge to look in the tank was that there was an octopus living in my tank – there are a surprising number of hoses in the tank. The first image shows the hose that had slipped through a zip tie and interfered with the float. I moved this hose toward the back of the car and the gauge works now. The second image is the tank gauge for reference.
The other possibility is that the gauge float was touching a vertical "pipe" (not sure what it actually is) that is toward the front of the tank. I rotated the tank gauge clockwise a small amount to reduce this possibility.
