I am installing the switch for the PSE. (I live in a neighborhood where I need the ability to shut it off.)
Is there a wiring diagram available? I cannot make out the relay and fuse connections from the written description contained in the related #2601 TSB. Specifically, there is a RE/BU wire with an attached connector that is longer than needed to reach the fusebox/relay area, so I cannot figure out where it goes. This wire is part of a group of RE/BU wires that are crimped together, including a long RE/BU wire that connects to the vacuum valve in the engine compartment and one that goes to terminal 15 of the PSE relay.
2002 C4S Coupe
