I'm considering a 2004 GT3 with 30,000 miles on the clock. The DME reading follows. The range 1 revs says 65535 (2^16) and that looks like the limit of the computer's memory. I know these are the type 1 over revs and should be safe, but is that still too high? Does that indicate this car's been tracked? Anything else you guys notice about these readings?
Derek
GT3 DME Vehicle data
Number of ignitions, range 1
65535 667.1 h
Number of ingitions, range 2
Operating hours counter
789.0
Vehicle Identification Nr.
WP0AC29984xxxxxxx
Type ID DME control unit
0996GUS01
Order type
996810
Country code
C02
Engine type
9679
Transmission type
G9696
Transmission number
2002852
Radio/PCM code
0000
Body color/convertible top color
12H0L
Interior equipment
490
Number of programming operations
2
Navigation system
0000
Total distance
047364km
Edited by Loren
removed VIN from post
You have no Range 2 over revs - you can not ask for better.
Range 1 over revs were caught by the rev limiter and don't mean much since the rev limiter protected the engine. Range 2 are the bad over revs.
