After the car was sitting in my garage for 1 week without driving, I decided to go for a drive when the factory alarm would not dis-arm itself after pressing the key button. It would not dis-arm and open the doors. I then manually open the driver's door with the key into the keyhole. I fired her up with no problem. Then, I tried arming and disarming the alarm with the key button with NO PROBLEM. What happened? Is it because I had not activated the alarm for a while that the factory alarm would not engage? No, it's not the key battery because it's brand new.
1999 cab 996
1999 cab 996
That is how it is supposed to operate. If you arm it and leave it for a period of time, you must use the key to open the car. After normal use, this is reset and will work as normal.
No issues...Just how it was designed to work.
Good luck.
DC
1999 cab 996
Good luck.
DC
OK!!! THANKS!!!
