I was thinking of breaking out the baffels inside my secondary catalytic converters.It is a heck of alot cheaper than replacing with a 400.00 bent tube..Does anyone know if that will throw the check engine lite or have any of you folks ever done this before...I have a 06 Titatium S. I am also powder coating brake calipers Porsche yellow and putting on crossdrilled rotors from R1 Concepts and the EVO dual KN filter intake. Car should rock!!!
Thanks for any input
Dave
Where are you located? I would strongly advise against it.... it's not like you can put that convertor substrate back together again if you encounter problems.
