1999 996 c2
I have recently gone through 3 mass air flow sensors in 2 months. My symptoms are hard starting...the engine cranks 15-20 times with me furiously pumping the gas pedal before it starts...
It is an intermittent problem. I get about 5-10 good starts per sensor before it happens (check engine light-mass air flow code) and then it comes and goes. Does anyone know what causes the mass air flow sensors to fail?
h
Has the intake been modified? Oil, used on aftermarket cold intake systems, has been known to contaminate a MAF sensor.
Edited by rprieto
MAF has nothing to do with starting and very little to do with idle. You can unplug the MAF and the car will run fine until about 4000 RPM.
Can you tell us ALL the fault codes you are getting?
Sounds more like a fuel system problem but you need to do the basics like check for engine codes as Loren stated.
