Hi Everyone:
Wondering if anyone else here have experienced this issue...
After handwashing m 2000 C4 the other day, I opened the driver's side door to clean the floormats. I noticed that the area right around the gas pedal was wet along with some of the carpeting covering the drive axle hump. It clearly suggests that water had been dripping down and collecting near the gas pedal.
Sound familar to anyone? In looking at the base of the windshield, nothing seems out of order. Certainly no obvious holes/cracks.
Help!
Hi Everyone:
Help!
If the liquid that collected there feels a little "viscous", double check your heater core radiator and the two hoses that lead to and from that little radiator. If there is a leak, it could end up dripping onto exactly the area that you have described.
Regards, Maurice.
