I recently was told that the 997.2 GT3 380 mm front and 350 mm rear steel rotors are "direct bolt-in" replacements for the 997.1 PCCB rotors. The 997.2 steel rotors are compatible with the 997.1 PCCB caliper as long as the proper brake pads are used.
Does anyone have the part numbers for the 997.2 GT3 front and rear steel rotors? Does anyone know if they are 2-pice and/or cross-drilled?
Thanks in advance for any assistance.
