In need of help, sometimes when I turn on my lights, turning to the right all the way, my Bi-Xenon lights won't come on, by returning the switch all the way to the left and quickly turning it to the right it sometimes comes on.
I suspect it might be in the switch???
Is there another component I should check as well?
I just tried it again, and after 4 times switching back and forth, it came on(both left and right) so it is definitely not the bulb.
And after switching it off after having it on for a minute, I was not able to get it to come back on.
HELP
Max
Thanks Loren.
The headlight switch has been a problem for others here too.
I would replace the switch.
Thanks Loren.
Recently, my light switch jammed up and could not turn off. I had to force it off by using force, and in the end I lost the "indexing" of my light switch. I think the "indexing" parts internally broke apart. Is the part the same for all 996 model years? Is it expensive?
Thanks Loren.
Same headlight switch for all model years.
996.613.535.00 Headlight switch -- US MSRP $124.47
