I recently installed a custom/aftermarket gt2 style wing on my C4S. It replaced the factory retractable unit. I used the -51 harness. The wing houses a third tailight, in addition to the oem unit below the window. Isn't there a oem 'blind' that plugs the oem slot below the window so I won't have fourteen tailights!
You will need to remove the original additional brake light. Then insert:
996 504 981 01 G2X Cover trim for installation opening of additional brake light (prime coated). There is a note in the C4S Aerokit instructions on this that says:
6 Install additional brake light cover trim.
6.1 Only for vehicles as of model year '04.
6.1.1 Clip in cover trim for installation opening of additional brake light.
6.2 Only for vehicles up to model year '04
6.2.1 Cut off all lugs (A) of the cover trim.
6.2.2 Apply adhesive compound (6) in the border area of the installation opening for additional brake light and insert cover trim.
Note: Select the size of the adhesive bead so that after pressing on the cover trim, any remaining adhesive is not visible from the outside.
6.2.3 Fasten cover trim with adhesive tape.
