2003 996 C4S manual tranny...
Driving down road and PSM/ABS failure comes on. I checked the brake light fuse and it was blown, (changed fuse 15A and nothing, tested voltage at fuse got nothing when brake pedal pressed), switched the brake pedal switch (still nothing), checked bulbs (all good)...
Any other suggestions on what to test next. All other lights work, parking, hazard, etc...
Thanks for the help....
Are you sure you had the correct switch on the pedal assembly? Try bridging the switch and see if lights operate.
