DIY Dension Gateway (MOST ipod) with CDR-23 and CDC-4 on Porsche 996 C2
The Dension Gateway Iceling 500, allows you to play your iPod/iPhone with your Porsche Radio. Note that cheaper solution are available if your system is not wired with fiber optics cable, aka MOST. I believe that all Porsche 911 were equipped with the fiber optic system after the model year 2002. This system is extremely easy to install if you have the OEM CD-changer CDC-4. Unplug the fiber optic cable going into your CD changer, plug it directly into the Dension, or use the extension
