Has anyone had need to find an ignition switched 12V (low current draw) in the front luggage compartment area somewhere?
If so, it would save me a lot of hassle if someone could tell me the best place to take 12V from.
Thanks.
996C2 MY2001 manual coupe
The search feature works great on this site. This has been discussed prior and there is a diagram provided by Loren.
Here is a link to a similar article that may meet your need: Link
DC
DC
Thanks CD for the reply, much appreciated.
I was looking for a switched on with the ignition 12V, that thread is about an unswitched permanent 12V
but the diagram is useful.
DC
Right...I realize that. But if you read Loren's statement in that post " Other than the horns or headlights most everything else up front is switched." I think you still get your answer....
Good luck.
DC
I haven't actually done this but one of the other members told me you can pick up low current switched 12v at the window washer nozzle heaters. Other than that there is no switched 12V in tte front compartment that I know of.
Thanks lex_gs
I have double checked that today with the multimeter after reading your reply.
PERFECT
It's very easy to get to those connectors just behind the battery for an ignition switched 12V.
As you say, after searching, it does seem that there are no other ignition switched 12V sources in the front.
Cheers :thankyou:
