Thought I'd share this with everyone.
Useful if you are thinking about using your Ipod in the car: (Hint - click on the underlined links)
Supposedly you can 'cheat the system' if you have a CD Changer using the CD-audio in connectors
Cheating the 210/220 by using the CD audio cables for MP3 feed
Another version of this bypass method
MP3 (not Ipod) hookup, showing same method
Use the telephone input - should work on CDR-220 and CDR-23. Don't know about the 210, but you can ask them
A place to order the Aux-input cable
but also :"For these units, Becker also sells a kit with an adaptor cable and tools for under $20 that lets you hook up an external sound source such as the iPod to the aux in, and you can select it on-screen after enabling aux in via the TP menu. (Part number 1319.116-276 from the Becker parts department at (888) 423-3537 x1209.)"
Disccussion (2000) regarding the MPEG feed in using the Aux/Phone cable connector
Warning that Becker is not compatible
but - supposedly doesn' t work yet with Becker
Icelink 1.1 car kit and Non P-car Icelink 1.1 review
Alternatively
A new device, unsure what it does with Becker - PAC AUX-POD
I don't know what this is
Becker mini ISO aux input - useable?
Reference to Leo Monney (redwood city) - he could answer questions
Archived discussion and Monney website
The tried and true - FM transmitter
Monster Cable FM transmitter
