I have a 2000 Boxster with the airbag light illuminated. I have reset the fault code but the light stays off only momentarily. It appears that there may be a control unit issue. Is it likely to be a control unit issue and is it possible for me to replace it easily?
The code will certainly help narrow it down.
If your code is "Ignition Circuit Driver" (code 21 IIRC) it will exhibit the exact symptoms that you are describing (i.e., the light goes off when you reset it, but goes back on a few seconds later). That fault can sometimes be resolved by repairing or replacing the "clockspring assembly" (ring under the steering wheel).
Regards, Maurice.
Regards, Maurice.
Yes the error code is 21.
You have to remove the steering wheel to test the clockspring assembly for continuity or to replace it.
Here is a part of some of the instructions which were written up for the installation of a 4 stalk control. You can use the pertinent parts for the steering wheel removal:
"Disconnect battery to car. Remove airbag cover using long (at Least 50mm) 30 torx socket from rear of air bag.
Pull connector off of air bag and set air bag down in an area away from where you are working, with the cover of the airbag
facing up.
Remove steering wheel using 24 mm socket, scribe mark on steering shaft and wheel to line up during assembly.
Remove horn wires and slide steering wheel off. Remove 2 small Phillips screws on side of black turn signal switch housing
Remove four screws on front of turn signal switch, loosen 8 mm bolt on bottom of turnsignal switch thru slot of black
Housing.
Separate black housing and remove 2 screws holding on Airbag spiral spring. ( be careful not to spin spiral housing or
Steering wheel or you will damage spiral spring)."
Let us know how you progress.
Regards, Maurice.
Hi all,
I have a simliar problem, except my light only comes on every so often and only on start up. I can clear it with the Durametric and it wont come back again while driving. It was happening once every couple of months but is now a bit more frequent (every couple of weeks).
It's the same code (21) but given the intermittent nature, and only on start up, is my problem likely to be the clockspring assembly, or should I start somewhere else? (BTW, it's an '02 Boxster S).
TIA
-Scott
Fault codes 4, 5, 20, 21, 36 -- Ignition circuit, driver
Possible cause of fault
- Short circuit to B+/ground or open circuit in the wiring between the driver's airbag unit and the airbag triggering unit
- Driver's airbag unit faulty
- Triggering unit for airbag faulty
Note: If the fault memory is cleared, the ignition must be switched off, the ignition key removed and the ignition switched on again in order to check the fault path. Only in this way is another self-test carried out.
Hi Loren,
Thanks very much for the reply. Over the last week or two, most times I reset the light I stop and start the car (remove key, etc) at least 4 or 5 times, sometimes more. It only seems to come back if I let it sit for a while then start it, and even then not each time. The frequency is totally random, but the one constant is it only occurs on start up.
Do you know where I can get very specific, step-by-step instructions on testing the areas you listed (pin numbers, plug locations, resistance values, etc)?
I know this is a big ask, but I really would like to get this fixed before I sell the car (have a potential buyer) and don't have much time to spend fault finding due to moving overseas on orders in less than 4 weeks.
-Scott
  • 3 years later...
hi rentech! i ran my 2000 boxster with the passenger seat out/unplugged now my airbag warning light stays on with the seat back in/connected how do i get it to go out or reset? thank you... scott
