Hi guys, it's me again.
I have another problem. I drive a '98 boxster 2.5L manuel transmission.
My headlights work when I have the engine and the lights on, but once I turn the engine off and leave the lights on, only the driver side low beam still works. I've replace the light bulb on both, and still doesn't work. I thought it maybe the headlamp itself that is faulty, so I ordered and new one, installed it and still does not work.
Does anyone have any solutions or know what I could try. Does it have anything to do with the fuse, if so where is our fuse box located?
Please advise,
DTM
No reason to think that the bulb is the problem as it can only tell if it is getting "juice" or not. But just to make sure, you do realize that the low beam is the upper bulb and vice versa. It is counterintuitive and I've gotten it wrong before.
Hey Mike,
Thanks for the info. Yeah, in either case, I changed out both bulbs, because I wasn't sure which one was out, but I still have the same problem. So when we turn on the engine and leave the lights on, it's the high beam that is still active?
Ok, it's just not as bright as the regular lights with the engine on, so that's why I assumed it was the low beam. Thanks for helping me clarify that.
Anyway, do you know what might be wrong with it?
Please advise, Thanks
DTM
I think you have your light bulbs mixed up. When you turn off the car, your head lights are supposed to turn off. Your parking lights will stay on though - there are wedge/parking lights, and it sounds like one of them is burned out. Its a special size bulb that is easy to replace but can be hard to find. I had to go to the dealership to get it as none of the local auto parts stores had them. I think it is a 5w bulb.
I was thinking just same thing, it must be the parking light and not the headlamp.
So you're saying there is another light that is wedged somewhere else? Yes! I think it is the parking light. because only the driver side light stays on when I turn the engine off. OK, let me look for that light.
Thank you so much
So where is the parking lite located?
When you turn your headlights "OFF", is the switch positioned straight up? Or, is it all the way to the left? If the switch position is all the way to the left, you have turned on the left parking and side marker lights.
Bill
Yes there is another light bulb (parking light), it's not wedged in anywhere - sometimes people call it a wedge bulb is all. If you have litronics its a H6W bulb, if your headlights aren't litronic, then its a W5W bulb. Sorry but I don't have a picture of where it's located - its there though, I've replaced it before. It's a small bulb if that helps.
