I've got an 04' Boxster S with adjustable intermittent wipers. The "intermittent" part doesn't seem to work. from what I've read I need to replace the #16 relay. Can someone please confirm that ie following is the correct part# for the boxster? ...
996.615.103.00
-Tomikaze
You might have the "rain sensor" option. In that case, the thumb wheel only affects the sensitivity to water on the windshield and adjusts the intervals accordingly. Page 111 of the 03 Boxster owner's manual describes the use of wipers with the "rain sensor" option. Try spraying water from a hose on the windshield with the car running and wipers turned on. Might save buying a new relay.
