Hi all
I am wondering if there are any ways to remove the cdr23 unit without the removal tools and whether a new headunit from Sony or alpine can just plug straight in ??
cg
there is a literal truckload of info on this forum about swithing out radios, reconfiguring control locations, etc. the search engine will be your best friend for information... good hunting.
You'll need the radio removal keys no matter what. Just search porsche radio removal keys on ebay and you can find some for under $4. That's how I got mine. Also, search the forum for CDR23, mobridge, dension 500, or nav tv and you'll see all the threads discussing the replacement of the CDR23. Then you'll discover that there is no cheap solution for what you want. Good luck.
