I just put in some new diverter valves which required removing the drivers side lower boost hose (the one from the turbo to the intercooler) and it now seems to be leaking under high boost. I heard there was a replacement o-ring for the intercooler fitting on that hose. Anyone have the part number and rough cost for that? Thanks, David
0 think it is #39... found this web page while searching, says it is about $6. ;)
My link
Loren, it looks like there are a lot of o-rings in this system. Does Porsche have a test for identifying boost leaks on a Cayenne Turbo?
Edited by Reborn996
Item 39 = 955.110.721.00 Round seal -- US MSRP $4.96
Not really - it will just give you the readings on each side - so I guess you can narrow it down to which side.
  • 8 years later...
