hi every one, car been running fine 996 t/t left work tonite on moterwat doing 50 mph, car just cut out, pulled to side of road would not start at all checked all fuses all ok felt like fuel starvation, got her home o low loader care of the AA breakdown, took pipe of fuel cannister pumping fuel no prob but still wont start, will try on the key for about 20 sec then she will fire up run for about 2 sec then cut out again, if i push down excellaretor pedal will not rev at all will just cut out any idears thanks mark
Bad petrol?
Water in the tank?
filled up day before yesterday was not reading on gauge so went into garage and filled up to 3/4 of tank from rep garage
